Support Center
First Use
Every Ruuvi sensor is shipped with a default Ruuvi firmware version installed, which enables Ruuvi sensors to be used with the Ruuvi Station mobile app right out of the box.
Ruuvi sensors are powered by a single CR2477 battery and are shipped in a waterproof enclosure, so they are ready for action. Choose the 2 in 1 pro version if you need to use the sensor in water for extended period of time. RuuviTag sensors are recommended to be used within -20°C to +65°C temperature range.
First Use
  • Open the enclosure.
  • Remove protective film from the top of the provided CR2477 battery, which is located inside the sensors battery holder.
  • Your Ruuvi sensor will power up automatically to its standard operating mode.
