Support Center
Graphs history is empty
Background scanning is disabled
Ruuvi Station will only listen to RuuviTags when the app is active in the foreground. Enable Background scanning in App Settings to run scans when the app is working the background.
App Data was cleared
Graphs history will be lost if Ruuvi Station data was cleared from your mobile device settings.
Ruuvi sensor is not powered
Indicator LED light will blink on the Ruuvi sensor, when the beacon is powered.
Bluetooth is disabled
Ruuvi Station requires Bluetooth (BLE) connection, check that your Bluetooth connection is enabled.
Check permissions
Ruuvi Station requires the following permissions in order to collect graphs data: Location, Storage.
RuuviTag signal is out of range
Bring the Ruuvi sensor closer to your mobile device. Make sure there are no structures between the Ruuvi sensor and your mobile device, which could obstruct the Bluetooth signal.
