Support Center
How does the RuuviTag actually work?
RuuviTag is an extreme low-power Bluetooth Low Energy sensor node that continuously measures temperature, relative air humidity, air pressure and acceleration.
Environmental variable measurements are taken every second, 24/7. After data is measured, RuuviTag prepares a Bluetooth message and broadcasts it out for nearby receiver to collect. The receiver can be a mobile phone or a gateway.
Even with sensor measurements and sending data every second the battery is expected to last up to 4 years. This means one battery has enough juice to measure and send up to 100 million times before running out of energy.
