Support Center
Is RuuviTag waterproof?
The RuuviTag resists water (IP67) but do not leave the breathing sticker on top of the lid to direct contact with water for long periods of time. Note also that if you do, air humidity and air pressure sensors won’t work well because water blocks the air flow.
If you want RuuviTag to measure long-lastingly under water, we recommend you to put it inside of a plastic bag or such.
Note also that radio waves barely travel under water so the Bluetooth range will be really bad.
