With Ruuvi sensors you can measure temperature, air humidity, air pressure and movement at home, in your hobbies, or at work.
Measure Your
World
With Ruuvi Sensors
Smart
Sensor Solutions
Ruuvi Products
- In stock
39,90€ - In stock
55,90€ - In stock
49,90€ - In stock
49,90€ - In stock
Ruuvi Gateway Router
199,00€ - In stock
Ruuvi Sensor Measurement Kit
339,00€ - In stock
Silicone Case for RuuviTag
4,50€ - In stock
Stand for RuuviTag
3,90€
How does it work?
Choose the best option for your needs:
Easy Start With One Sensor
Easy to Use Environmental Monitoring System
For an easy to use measuring solution you will need only one or a few Ruuvi sensors and the Ruuvi mobile app. Ruuvi sensors send measurement data, which can be read with a smartphone, via Bluetooth. In the app, you may set alerts and customise the sensors to your liking.
This setup is up and running within a few minutes. No pairing is needed.
More Features With the Cloud
Complete Solution
for All Monitoring
You will get all the best features with Ruuvi sensors and Ruuvi Gateway. The Gateway routes the sensors’ data to Ruuvi Cloud (new gateway owner gets a free Pro Cloud plan for 6 months).
The Cloud enables remote monitoring via the Internet with trusted email alerts and longer history. With Ruuvi Gateway you will also get a longer Bluetooth range for your sensors.
The Gateway works with your own Internet connection via a Wi-Fi or an Ethernet connection.
For Advanced Users
Ruuvi products are open-source. You can configure the Gateway to send data to a third-party cloud service and integrate Ruuvi to your existing system.
Sensors -> Gateway -> Cloud -> Mobile & desktop app
Trusted by the Largest Companies
Ruuvi products are designed perfectly fit both consumer and business uses. Ruuvi has already over 5 000 business customers located in 100+ countries.
Get your own measurement buddy!
Buy more, save more.
Quantity | Unit Price(€) |
1 | 39,90 |
2 | 35,90 |
3-5 | 33,90 |
6-8 | 32,90 |
9-12 | 31,90 |
13-25 | 30,90 |
26-99 | 30,50 |
RuuviTag is a Bluetooth sensor that sends temperature, relative air humidity, air pressure and motion information directly to your mobile phone. Read more
Technical Specifications
FREE
SHIPPING
For orders over
100 €.
MADE IN
EUROPE
Designed and assembled
in Finland.
SATISFIED
USERS
Our return rate is
less than 0,1 %.
QUICK
SUPPORT
Fast response time to
all messages.
