Support Center
Ruuvi sensor is not starting
Ruuvi sensor is not powered
First run: remove the resist between the battery and the battery clip. Indicator LED light will blink on the Ruuvi sensor when the beacon is powered. Change the battery if the LED indicator continues to be off.
