Support Center
Scan results not sent to the server when using data forwarding
Internet connection
Check that your internet connection is enabled and you have access to the internet.
Background scan
Ruuvi Station will only listen to Ruuvi sensors when the app is active in the foreground. Enable Background scanning in App Settings to run scans when the app is working in the background.
Scanning interval
Ruuvi Station will send background scan data to data forwarding URL according to scanning interval setting in App Settings > Set scanning interval.
Wrong URL
Check that your URL address is correct.
