In Alert Notifications users can manage the way alert notifications are behaving in Ruuvi Station mobile app.
Please notice that these settings control notifications triggered by Ruuvi Station app. Notifications can also be controlled and limited by your mobile operating system. Check your system settings to manage notification permissions, styles, grouping, and set limits on when notifications should be displayed.
Limit alert notifications
This feature is only available in Ruuvi Station mobile apps.
This setting will limit receiving local Bluetooth alert notifications in Ruuvi Station mobile app to a single notification per hour. When enabled user will receive second notification for triggered alert after 1 hour has passed if the value is still over the threshold. This setting doesn’t limit alert notifications received from Ruuvi Cloud.
Limit alert notifications is enabled by default in App Settings.
Email alerts
On mobile, this setting is visible in Ruuvi Station mobile app when you are signed in to Ruuvi Station.
On web, this setting can be found under Settings.
If you are using Ruuvi Cloud and Ruuvi Gateway, you can choose to enable or disable alert notifications via email, sent to the email address linked to the Ruuvi account you used to sign in to Ruuvi Station app.
Please notice that receiving alert notifications via email requires Consumer Pro subscription level or higher.
Push alerts
This setting only affects receiving push notification messages to mobile devices (iOS, Android) that have Ruuvi Station app installed and user is signed in.
If you are using Ruuvi Cloud and Ruuvi Gateway, you can choose to enable or disable alert notifications on your mobile devices (iOS, Android) that have Ruuvi Station app installed and when you are signed in to Ruuvi Station app.
Please notice that receiving push alert notifications requires Consumer Basic subscription level or higher.
Sound notifications
Sound alerts are handled slightly differently in iOS and Android devices.
Alert Sound setting is using the iOS system setting under Settings -> Notifications
You will be able to choose between Ruuvi Alert sound or System Default alert sound in Alert Sound settings. Additionally, iOS uses the Sounds & Haptics system setting for adding vibration to sound alerts.
Sound Settings in Android system is using the Settings -> Notifications ->Ruuvi Station -> App notification setting
For general notification settings, you will be able to choose to allow sound and vibration or deliver quietly in App notifications.
For general sounds and vibration settings you will be able to choose between Sound modes, choose different ringtones and adjust vibration intensity.
