App Settings: Data Forwarding (Android)
Data forwarding is an advanced feature of Ruuvi Station (Android only) and it’s mainly intended for power users.
With this feature, you can let the app act as a gateway, forwarding measurements collected in Ruuvi Station to an HTTP endpoint using POST requests.
Ruuvi Station app will act as a gateway, when:
  • Background scanning is enabled, and
  • A valid Data Forwarding URL has been added in Data Forwarding settings
If the above-mentioned conditions are fulfilled, Ruuvi Station app will POST background scanning results to the specified URL.
Data forwarding uses data logging intervals, which can be set in Background Scanning settings as explained above.
Note! Data forwarding is not connected to Ruuvi Cloud and cannot replace features offered by using a Ruuvi Gateway router and Ruuvi Cloud subscription.
