App Settings: Global Units
In Ruuvi Station, go to App Settings – Global units to choose the default units used in the app.
In Ruuvi Station mobile app, go to App Settings to change Global units.
In Ruuvi Station web app, go to Settings Menu – Settings to change Global units.
Global units are localised measurement-unit choices. They are used as part of the defaults in Visible measurements whenever Use default is enabled.
When Use default is enabled in Visible measurements, the sensor card uses the units selected under Global units.
When Use default is disabled, changes made under Global units do not affect that sensor card. The card uses the units selected in its own Visible measurements settings instead.
The following global measurement units are available:
  • Temperature: Celsius (°C), Fahrenheit (°F), and Kelvin (K)
  • Humidity: Relative humidity (%) and Absolute humidity (g/m³)
  • Air pressure: Pascal (Pa), Hectopascal (hPa), Millimetre of mercury (mmHg), and Inch of mercury (inHg)
Dew point: Dew point is no-longer available in Humidity options. If Dew point was selected previously under Humidity, Ruuvi Station will not automatically change the existing selection to another humidity unit. Dew point can be brought to a sensor card by setting Use default disabled in Visible measurements and adding it from hidden measurements to visible measurements list using ‘+’.
Global units don’t affect the CSV, XLXS exports.
