Configuring Gateway using Ethernet
First login:
If you are connecting to Gateway through Gateway Hotspot “RuuviGateway XXXX” no password is needed. If you connect through local area network, you need to authenticate with user “Admin” and password “XX:XX:XX:XX:XX:XX:XX:XX” printed in sticker under the Gateway. Configuration wizard allows you to set up advanced authentication options, if you lose your log in information press the button under power connector with pin delivered with the gateway or a paper clip for 10 seconds to do a factory reset and login again with default password”
