Ruuvi has worked together with mesh protocol creator Wirepas for almost three years now. RuuviTags can run their proprietary mesh protocol stack instead of the Bluetooth stack which we normally use. This enables large battery-powered low-power mesh sensor networks. Those kinds of networks aren’t and won’t be possible to build with Bluetooth Mesh protocol. The market potential is huge.
In the end of June 2018 Wirepas organised a yearly 3-day Wirepas GO event for their partners and customers. In June 26th Henri, Otso and me headed to Clarion Hotel, Helsinki, where the event took place.
For Ruuvi, the event was extremely beneficial. We met with several companies who are using RuuviTags in their end-products and also gained awesome new connections and business leads. Big things are coming.
We want to thank Wirepas for organising the event and also all our current and future customers and business partners! Guys, see you next year 😎
More Info
Read on RuuviLab how Wirepas’ mesh protocol superpowers RuuviTags.
Join the journey!
Onboard Sensors (4-in-1)
Operational Conditions
App Features
Platforms: Android and iOS.
Compatibility
Technical Specifications
Data sheet: Download (pdf)
Read more info below:
Excellent!
Battery Box
Engel Fridge
Main Rapido Fridge Area
I have now configured:
High temperature alarms
Low temperature alarms
VRM email notifications
the battery box overheats
