Since the RuuviTag project was launched in 2015, we’ve also created customised products for clients who have requested something similar. On some of those projects, we have used Promistel Industries’ services and have been extremely happy with the cooperation with them.
Recently, we also decided to start building RuuviTags together and now it was about time to finally take a flight to France and go to see their campus.
Promistel Industries is an electronics company founded in 1983 and is located close to Paris.
Their state-of-the-art production facility has everything that is needed to build embedded electronic products like RuuviTag:
I need to say that during my 2-week visit to France, I was impressed about how clean and professional the factory was and how effectively they operated. I also noticed the staff had a high work ethic and their style of handling things was always professional and precise.
In the past ~8 years, I’ve dealt with numerous circuit board and electronics assembly factories around the world. Sometimes everything goes as planned but usually not. In this business, mistakes are expensive and can cause severe problems to customers. Especially, if deliveries get delayed without notice.
With Promistel, we can rely on their ability to deliver quality products in time.
Would you like to have one?
Onboard Sensors (4-in-1)
Operational Conditions
App Features
Platforms: Android and iOS.
Compatibility
Technical Specifications
Data sheet: Download (pdf)
Read more info below:
Toimii hyvin
