World wide free shipping on orders over 120โ‚ฌ - Paypal and Stripe payments - Made in Finland
LED indicator codes and button functions in Ruuvi Air
The Ruuvi Air has a two LED indicators – one located at the bottom of the device and one (main LED) at the front facing panel of Ruuvi Air. These LED indicators will tell you when your device is working correctly or indicate various errors with colour combinations.
Use this simple guide to quickly check the status of your Ruuvi Air. If you require more detailed information about LED indicators, please refer to docs.ruuvi.com
Bottom LED indications
LED step length is 100 ms.
In the below list, indication codes are represented as follows:
โ€œ๐Ÿ”ดโ€ represents the red LED being on
โ€œ๐ŸŸขโ€ represents the green LED being on
โ€œ-โ€ indicates that the LEDs are off
Sensor booting, red shown for 500ms once.“๐Ÿ”ด”
Normal operation. Peripheral sensors polling 1/s.“๐ŸŸข-”
NFC event triggered.“๐ŸŸข-”
Button pressed.“๐ŸŸข+๐Ÿ”ด”
Solid red. Firmware loader is active and waits for connection.“๐Ÿ”ด”
Solid green. Firmware loader is active and connected.“๐ŸŸข”
Error: Factory flashed firmware recovery fail.“๐Ÿ”ด-๐Ÿ”ด- ———“
Error: System has halted.“๐Ÿ”ด-๐Ÿ”ด-๐Ÿ”ด- ———“
Error: software assert triggered.“๐Ÿ”ด-๐Ÿ”ด-๐Ÿ”ด-๐Ÿ”ด- ———“
Main LED indications
โ€œ๐Ÿ”ตโ€ represents the blue LED being on
โ€œโšชโ€ represents the white LED being on
Blue LED brightness increases from 0 to 100% for 500 ms. After boot device is waiting for first air quality measurement to become valid.“-๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต๐Ÿ”ต-“
Blue LED flashes once per second. Firmware loader is active.“๐Ÿ”ต———-“
White LED brightness increases from 0 to 100% for 500 ms. Firmware update in progress.“-โšชโšชโšชโšชโšชโšชโšชโšชโšช-“
Error: No valid air quality received in 30 seconds, or SEN66 sensor is disconnected/unresponsive.“-“
Pinhole button functions
Locate the pinhole button at the bottom of Ruuvi Air to access various button functions as described below.
Change main LED brightnessShort button press
Activate firmware loaderButton press +5 seconds
Activate factory flashed firmware recoveryButton press 5+10 seconds
