How to Prevent Condensation Problems When Installing RuuviTag Sensors
Measuring environmental conditions with RuuviTags can offer valuable insights, but condensation remains a sneaky challenge that can affect sensor longevity and data accuracy. In this extended guide, we’ll break down step-by-step recommendations, loaded with practical examples, so you can ensure your sensors stay accurate and last for years, whether at home, in vehicles, or in harsher outdoor environments.
Why Condensation Is a Problem
Condensation occurs when humid air contacts surfaces cooler than the surrounding air, often causing tiny water droplets to form. For digital sensors like RuuviTags, this is more than a minor annoyance:
  • Interferes with readings: Water droplets on or near the sensor element can skew humidity and temperature measurements.
  • Causes corrosion or short circuits: Tiny traces of moisture can lead to rust, cause excessive battery consumption, or degrade electronic contacts over time.
The key is to prevent condensation from forming in the first place, starting with your installation choices.
General Installation Tips for All Environments
No matter where you install your RuuviTag, these best practices make a huge difference in keeping condensation away:
  1. Avoid metal contact points: Metal acts as a thermal bridge, cooling rapidly to dew point levels. Instead, mount your sensor on wood, plastic, or other non-conductive materials.
  2. Use RuuviTag silicone holder: This will act as an insulation between the material and RuuviTag sensor to reduce a risk for condensation.
  3. Keep it away from stagnant corners: Tucked-away, unventilated spots are prime locations for moisture buildup.
  4. Avoid direct exposure to water sources: Keep at least 1–5 m from humidifiers, kettles, sinks, or open tanks and protect from rain or splashing water.
  5. Position for airflow: Install where natural air movement is present; near open shelves, doorway air paths, or gentle fans.
  6. Mount vertically or with a downward tilt: This prevents moisture from running onto measurement elements.
  7. Use protective membranes: RuuviTag uses a breathable membrane that balances airflow with splash resistance. Fully closed RuuviTag Pro 2in1 can have a higher risk for condensation.
  8. Raise it above floor level: Ideally 1.2–2 m high for indoor measurements; prevents exposure to ground condensation.
  9. Avoid closed plastic boxes without ventilation: These trap moisture and delay sensor response.
  10. Place away from heating/cooling vents: Turbulent temperature swings can lead to rapid condensation events.
  11. Check periodically: Especially after big temperature shifts, look for visible droplets or condensation rings.
Special Notes for Vehicle, Boat and RV Use
Vehicles, boats, and RVs pose extra challenges due to rapid temperature changes, conductive metal structures, and vibration. Follow these targeted tips:
  • Avoid mounting on exposed metal bodywork: Panels, doors, and floor sections are condensation hotspots after cold nights.
  • Pick interior, insulated locations: Inside cupboards, behind dashboard trim, or on fabric-covered walls.
  • Keep away from single-pane windows: They cool rapidly and attract condensation on cold mornings.
  • Avoid engine-adjacent areas: Heat from the engine followed by cooling at night makes moisture more likely.
  • Mount away from powerful ventilation outlets: Sudden temperature drops from AC can fog sensors.
  • Cold storage, fridge: Avoid contact with cooling elements or interior metal walls
Common Mistakes and How to Avoid Them
When condensation problems happen, it’s usually due to a few recurring installation errors. Here’s what to watch out for and how to fix them:
  1. Mounting directly on metal: Use adhesive foam pads or Ruuvi Silicone Holder
  2. Placing in stagnant, enclosed spots: Choose a more open location.
  3. Installing beneath dripping surfaces: Never place under air-con units, pipes, or window sills prone to water droplets.
  4. Obstructing Goretex membrane on the sensor: Ensure no tape, adhesives, or dirt covers them.
  5. Not accounting for environment changes: Relocate or adjust setup seasonally if needed.
Installation Checklist for Reliable RuuviTag Operation
Before you declare your setup done, go through this quick checklist to catch any potential condensation risks:
  • Is the sensor off metal surfaces or thermally insulated from them?
  • Is there free airflow on all sides?
  • Is it safe from direct water exposure and at least 1 m from humidifiers?
  • If outdoors: Is the mounting angle vertical or facing down?
  • Is it in a well-ventilated space, away from stagnant air pockets?
  • Does the location handle temperature changes gently (not near vents or uninsulated walls)?
  • If outdoors or on a vehicle, is there adequate enclosure or membrane protection?
  • Have you planned for easy seasonal checks or cleaning?
Bottom line: Proper placement is the biggest factor in ensuring RuuviTags deliver years of accurate, worry-free monitoring. And now that you understand why condensation forms, you can confidently make placement decisions that prevent it before it starts.
Science Corner: Why Condensation Forms
If you’ve ever seen droplets form on a cold window in winter, you’ve watched condensation in action. The exact moment air moisture becomes liquid is determined by the dew point temperature: the temperature at which air of a given relative humidity becomes saturated.
The simplified dew point formula (Magnus-Tetens approximation):
Tdewaγ(T,RH)bγ(T,RH)
Where:
γ(T,RH)=b+TaT+ln(100RH)
T = Air temperature (°C)
RH = Relative humidity (%)
a = 17.27, b = 237.7 °C (constants for water over liquid phase)
Example: If it’s 22 °C indoors with 60 % RH, the dew point is around 14 °C. Any surface (like a chilled metal beam) that reaches 14 °C or lower will have condensation.
This is why:
  • A cold metal wall in an RV after a chilly night can be dripping wet by morning.
  • Placing a sensor directly against a metal container in a cold garage almost guarantees moisture exposure.
Reference: ASHRAE Handbook – Fundamentals, Ch. 22 “Psychrometrics”.
Notes:
Small fridges are sometimes very challenging as if the sensor is in a location where temperature is changing a lot there is a risk for condensation. Condensation can also happen due to sensor touching cooling elements or walls (frost is an indication of condensation). Inside a fridge it would be better to use RuuviTag Pro 3in1 instead Pro 2in1 as Goretex membrane is allowing air to ventilate.
To ensure reliable performance, follow these guidelines when placing your RuuviTag sensor outdoors:
Avoid Direct Sunlight: Exposure to direct sunlight can cause temperature spikes, leading to inaccurate readings and increasing the risk of condensation. Install the sensor in a shaded area whenever possible.
Protect from Rain, Snow, and Moisture: Place the sensor in a location shielded from rain, snow, and excessive moisture to prevent water damage.
Ensure Proper Ventilation: Choose a spot where is free air flow to allow air circulation and minimize humidity buildup, reducing the risk of condensation inside the sensor.
