Ruuvi + ROAM Devices: Advanced Wireless Environmental Monitoring for Modern Boaters
ROAM Devices, a leader in remote vessel monitoring, has partnered with Ruuvi to bring the rugged RuuviTag Pro Bluetooth sensor to the marine world. This collaboration empowers boat owners with advanced, real-time environmental data making vessel management safer, smarter, and more convenient than ever.
ROAM and Ruuvi: Advanced Wireless Monitoring for Boats
Easily add the Ruuvi Tag Pro to the Roam Hub through the Roam mobile app and enjoy the ability to view temperature, humidity and pressure from anywhere.
ROAM Devices: Remote Monitoring for Peace of Mind
ROAM Devices specializes in affordable, cellular-connected monitoring solutions for boats and other remote assets. The Roam Marine Monitor Hub, paired with the intuitive Roam app, allows users to track critical parameters such as:
  • Temperature and humidity
  • Battery voltage
  • Bilge pump status and high water alarms
  • GPS position and anchor monitoring
  • Accelerometer readings for motion and impact
With real-time alerts and remote access from anywhere, ROAM gives boaters true peace of mind whether at the dock, at anchor, or miles away from their vessel.
RuuviTag Pro: The Toughest Wireless Sensor for Demanding Conditions
The RuuviTag Pro is a professional-grade, open-source Bluetooth sensor designed for harsh environments. Key features include:
  • Multi-sensor capability: Measures temperature, humidity, air pressure, and acceleration (RuuviTag Pro 4in1)
  • Extreme durability: IP67/IP68/IP69K waterproof ratings depending on model, rugged polycarbonate enclosure
  • Wide operating range: -40°C to +85°C, ideal for marine and outdoor use
  • High accuracy: ±0.1°C temperature accuracy, ±2% typical humidity accuracy  (3in1/4in1 models)
  • Long battery life: Up to two years with included CR2477T battery
  • Easy integration: Seamless pairing with Roam Hub and app
Why Combine ROAM Devices with RuuviTag Pro?
Smarter, Safer Boating
Traditional boat monitoring systems often lack granular environmental sensing or require complex installation. With RuuviTag Pro and ROAM, users benefit from:
  • Remote, real-time data: Check temperature, humidity, and more from your Roam Marine Monitor App no matter where you are
  • Customizable alerts: Get notified instantly if cabin temperatures spike, freezers thaw, or humidity rises preventing costly damage
  • Easy expansion: Add multiple RuuviTag Pros to monitor different compartments, engines, or storage areas
  • Simple installation: Wireless sensors mean no drilling or complicated wiring, just place and connect in the app
  • Data logging: Review historical trends to spot issues before they become problems
Versatile Use Cases
  • Monitor engine rooms, cabins, and storage lockers for overheating or freezing
  • Track humidity to prevent mold and protect sensitive electronics
  • Receive alerts for abnormal boat movement, impacts, or unauthorized access
  • Keep food, medicine, or supplies at safe temperatures on long voyages
How Does It Work?
  1. Install RuuviTag Pro sensors in key locations on your vessel.
  2. Connect sensors to the Roam Hub using the Roam mobile app.
  3. Monitor real-time data and receive alerts on your phone or web dashboard.
  4. Review historical data for compliance, troubleshooting, or maintenance planning.
Who Benefits from the ROAM + Ruuvi Collaboration?
  • Recreational boaters and liveaboards wanting peace of mind
  • Charter operators and fleet managers needing reliable remote oversight
  • Anyone seeking to protect their investment and avoid costly surprises due to environmental changes
The partnership between ROAM Devices and Ruuvi brings together best-in-class marine monitoring and robust, precision environmental sensing. With RuuviTag Pro sensors now available for ROAM systems, boaters can enjoy comprehensive, wireless monitoring making life on the water safer, more comfortable, and worry-free.
Stay Updated with Ruuvi Innovations!
Sign up now and never miss a wave of innovation!
Want to stay ahead in technology and IoT solutions? Subscribe to our newsletter for the latest updates, product news, and insights into smart innovations and articles like Ruuvi and Digital Yacht collaboration.
Almost ready…
Select topics you're interested in:
FAQ: ROAM Devices + RuuviTag Pro
What does the ROAM + Ruuvi partnership offer?
ROAM Devices now officially supports RuuviTag Pro Bluetooth sensors, enabling seamless integration for advanced environmental monitoring on boats and remote assets.
How do I add a RuuviTag Pro to my ROAM system?
Simply place the sensor in your desired location and use the Roam mobile app to connect it to your Roam Hub. The app will display real-time data and allow you to set up alerts.
What can I monitor with RuuviTag Pro and ROAM?
You can monitor temperature, humidity*, air pressure**, and acceleration (motion/impact) in real time, and review historical data for trend analysis and troubleshooting.
* Only RuuviTag Pro 3in1 & 4in1
** Only RuuviTag Pro 4in1
Is the RuuviTag Pro waterproof?
Yes. Depending on the model, RuuviTag Pro is rated IP67, IP68, or IP69K, making it suitable for harsh marine environments.
How accurate are the sensors?
RuuviTag Pro offers high accuracy: ±0.1°C for temperature, ±2% typical accuracy for humidity (3in1/4in1 models), and ±1 hPa for pressure.
Can I use multiple sensors on one boat?
Absolutely. You can add several RuuviTag Pros to monitor different areas, all managed through the same Roam Hub and app.
How long does the battery last?
The included CR2477T battery typically lasts 12-24 months depending on usage and environmental conditions.
Can I access my data remotely?
Yes. The Roam app and web dashboard provide remote access to all sensor data and alert settings from anywhere with an internet connection.
Who should use ROAM with RuuviTag Pro?
Any boat owner, fleet manager, or remote asset operator who wants reliable, wireless, and accurate environmental monitoring for safety and peace of mind.
