Ruuvi + Digital Yacht: Precise Environmental Monitoring for Your Boat’s NMEA 2000 Network
Ruuvi’s sensor solutions, such as RuuviTag and RuuviTag Pro, bring a new dimension to boating when combined with Digital Yacht’s innovative solutions. In this article, we explore how Ruuvi sensors seamlessly integrate with Digital Yacht products, such as the NAVLink Blue device and NjordLink gateway, providing accurate environmental data directly to your boat’s NMEA 2000 network.
Ruuvi and Digital Yacht: The Perfect Combination for Boating
Digital Yacht is known for its high-quality marine electronics products, and now they’ve taken a step forward by integrating Ruuvi sensors into their solutions. This collaboration enables boaters to collect and utilize more accurate and diverse environmental data than ever before.
NAVLink Blue: The Bridge Between Ruuvi Sensors and NMEA 2000
NAVLink Blue is a NMEA 2000 Bluetooth interface developed by Digital Yacht that reads data from Ruuvi sensors and converts it into NMEA 2000-compatible format. This allows temperature, humidity, and air pressure readings to be displayed directly on your boat’s multifunction display.
Reliably monitor temperature, humidity and barometric pressure on your NMEA 2000 navigation system
Key features:
  • Supports up to 16 RuuviTags simultaneously
  • Compatible with most modern multifunction displays (Garmin, Raymarine, Navico, etc.)
  • Easy to install and configure via web interface
  • Enables monitoring of multiple areas on the boat
By having an environmental sensor, such as RuuviTag, on your boat, you can make the conditions in the cabin more comfortable, ensure food and battery safety and the well-being of your boat in general.
Advantages of Ruuvi Sensors in Boating
Ruuvi sensors offer many benefits to sailors:
  1. Accurate temperature monitoring: Monitor critical areas such as the engine room or cold storage spaces.
  2. Humidity control: Prevent mold and moisture problems in your boat.
  3. Air pressure monitoring: Predict weather changes and prepare for upcoming conditions.
  4. Wireless and easy installation: No need for complex wiring.
  5. Long battery life: Operates for up to 1-2 years on a single battery.
NjordLink: Boat Data to the Cloud
Digital Yacht’s new NjordLink gateway takes boat data management a step further. It enables all boat data, including Ruuvi sensor measurements, to be transferred to the cloud. This opens up new possibilities for data analysis, remote monitoring, and developing innovative applications.
Overall, RuuviTag provides a convenient and effective way to monitor environmental conditions on a boat, helping to improve safety, performance, and overall enjoyment of boating.
Practical Applications
Engine Compartment Temperature Monitoring
Monitoring the temperature of the engine compartment, batteries, and equipment spaces is crucial for boat maintenance and safety. By placing a RuuviTag Pro in these areas, you can obtain real-time data that allows you to:
  • Detect overheating early and prevent severe engine damage
  • Monitor cooling system efficiency during long trips
  • Ensure battery performance
  • Identify deviations from normal operating temperatures, which may indicate maintenance needs
Weather Forecasting
RuuviTag’s accurate barometer, combined with Digital Yacht’s systems, enables local weather forecasting:
  • Track changes in air pressure and identify approaching weather fronts
  • Combine air pressure data with other weather parameters for a more comprehensive forecast
  • Compare local measurements with broader weather forecasts for a more accurate picture
  • Make informed decisions in route planning and selecting anchorage spots
Cold Storage Monitoring
Ruuvi sensors help ensure that your boat’s refrigeration systems are operating optimally:
  • Continuously monitor refrigerator and freezer temperatures
  • Set alerts for critical temperature thresholds to ensure food safety
  • Optimize energy consumption by adjusting refrigeration settings based on measurement data
  • Detect refrigeration malfunctions early and prevent food spoilage
Moisture Management
Moisture management is essential for maintaining your boat’s condition. With Ruuvi sensors, you can:
  • Monitor humidity in critical areas such as the cabin and storage spaces
  • Prevent mold and moisture problems by responding to elevated humidity levels promptly
  • Optimize ventilation and dehumidification systems based on measurement data
  • Protect sensitive electronic devices and navigation equipment from excessive moisture
Remote Monitoring via NjordLink Gateway
Digital Yacht’s NjordLink gateway takes boat condition monitoring to a new level:
  • Check your boat’s conditions in real-time anywhere, anytime from your smartphone or computer
  • Receive alerts for abnormal conditions, such as sudden temperature changes or humidity spikes
  • Track long-term trends in your boat’s conditions and use this information for predictive maintenance
  • Easily share boat status information with others, such as maintenance personnel or family members
These and many other practical applications make Ruuvi sensors and Digital Yacht solutions together offer a comprehensive and user-friendly system for monitoring and managing boat conditions. This technology not only improves boating comfort and safety but also helps boat owners make data-driven decisions and optimize boat use and maintenance.
Seamlessly integrate RuuviTag sensors with NAVlink in just a few simple steps.
Installation and Setup
Combining Ruuvi sensors with Digital Yacht products is designed to be as simple as possible:
  • Connect NAVLink Blue to the NMEA 2000 network.
  • Place RuuviTags in desired locations on your boat.
  • Configure NAVLink Blue via the web interface and connect RuuviTags.
  • Enjoy real-time environmental data on your multifunction display!
Summary
Integrating Ruuvi sensors with Digital Yacht solutions opens up new possibilities for boaters to monitor environmental data more accurately and comprehensively. By combining Ruuvi’s precision and reliability with Digital Yacht’s innovative products, boaters can now get a more complete picture of their boat’s conditions and environment. This not only improves safety and comfort but also enables data-driven decision-making at sea.
Tell us about your project or wishes with Digital Yacht and Ruuvi measuring devices on our forum!
Comment Regarding the Collaboration
“We’re excited to team up with Digital Yacht, bringing precise environmental monitoring to sailors and all folks who love being on the water. By integrating our RuuviTag sensors with their clever NAVLink Blue and NjordLink systems, we’re giving boaters – whether they’re sailing or cruising – access to crucial data right through their NMEA 2000 networks and the cloud. It’s pretty cool to see how two tech-savvy companies can create practical solutions that make life on the water safer, more comfortable, and just plain smarter. From keeping an eye on critical locations to helping predict local weather, we can’t wait to see how this combo transforms the boating experience for everyone out there!”
Henri Hakunti, COO, Co-Founder of Ruuvi Innovations
Stay Updated with Ruuvi Innovations!
Sign up now and never miss a wave of innovation!
Want to stay ahead in technology and IoT solutions? Subscribe to our newsletter for the latest updates, product news, and insights into smart innovations and articles like Ruuvi and Digital Yacht collaboration.
Almost ready…
Select topics you're interested in:
