RuuviTag is an advanced open-source sensor platform that can measure temperature, relative air humidity, air pressure and acceleration.
RuuviTag comes with several appealing features:
1.CE / FCC / RoHS / IP67 / Bluetooth certifications
2. Approved by Google — the world’s first open-source beacon with full support for Eddystone.
3. Easy to use — works out of the box and software updates are made easy.
4. Measures temperature, relative air humidity, air pressure and acceleration.
5. Wirepas Connectivity mesh — networks with an unlimited number of nodes.
6. Long range RF antenna.
7. Espruino JavaScript interpreter — easy prototyping.
8. Several year theoretical battery lifetime.
9. An integrated NFC (Near-Field-Communication) antenna.
10. 100% open-source both hardware and software.
Technical Specifications
Would you like to have one?
| 1 | 39,90 € | |
| 2 | 37,40 € | -6,3 % |
| 3-5 | 36,90 € | -7,5 % |
| 6-8 | 35,90 € | -10,0 % |
| 9-12 | 34,90 € | -12,5 % |
| 13-25 | 33,90 € | -15,0 % |
| 26-99 | 32,90 € | -17,5 % |
Onboard Sensors (4-in-1)
Operational Conditions
App Features
Platforms: Android and iOS.
Compatibility
Data sheet: Download (pdf)
Read more info below:
brilliant for seeing a history of the atmospheric pressure
Works really great. The damn AI just implied that this can directly control the IP. Now I’m planning to get a Gateway.
Works well
