Buy Now!
Rugged Wireless Temperature and Humidity Sensor
RuuviTag Pro Bluetooth Sensor
4.9 18 reviews
Total : 49,90 + shipping
Made in Europe, Finland. Worldwide free shipping on orders over 120 €.
RuuviTag Pro is a rugged IP certified environmental sensor for temperature, air humidity, air pressure and acceleration monitoring. The RuuviTag Pro is based on RuuviTag’s successful concept and additionally brings several outstanding features to the table. RuuviTag Pro is the toughest open source sensor on the market and it fits perfectly with demanding industrial and serious home uses.
RuuviTag Pro monitors environmental conditions and sends the data directly to your mobile device. Ruuvi Station mobile app allows you to view real-time accurate measurements and historical graphs. The app also provides customisable alerts to notify you of critical conditions, such as a melting freezer, excessively high bedroom temperatures that could disrupt sleep, or elevated humidity levels in your basement.
RuuviTag Pro or RuuviTag?
RuuviTag Pro and RuuviTag use the same circuit board design and operate on the same principles. The RuuviTag Pro features a more accurate temperature sensor, a more durable enclosure, improved mounting options, and a wider operating temperature range battery. If you’re unsure whether the basic RuuviTag will meet your needs, especially if you plan to use the sensors in extreme conditions or industrial environments, we recommend selecting the RuuviTag Pro. Please refer to the technical specifications for more details.
Operational Conditions
Operating temperature (with stock battery): -40 °C to +85 °C (-40 °F to 185 °F).
Housing (4in1 and 3in1) water protection level: IP67, splash-proof, non-condensing location.
Housing (2in1) water protection level: IP68 & IP69K, hot pressurised spray.
Battery: User-replaceable CR2477T (included).
App Features
Platforms: Android and iOS.
RuuviTag Pro 4-in-1
Temperature: °C, °F, K; typical accuracy ±0,1 °C @ 5-60 °C (±0.36 °F @ 41-140 °F).
Air humidity: RH-%, g/m3, dew point; typical accuracy ±2 RH-% @ 20…80 %. Range: 0-95 %.
RuuviTag Pro 3-in-1
RuuviTag Pro 2-in-1
Compatibility
Technical Specifications
Data sheet: Download (pdf)
Read more info below:
-40 ºC to +85 ºC
Battery
1000 mAh CR2477T battery (included)
Radio protocols
Bluetooth (default), Wirepas mesh, Lumenradio mesh, Bluerange mesh, Other 2,4 GHz proprietary protocols
Temperature sensor accuracy
Absolute accuracy ±0,1 °C, output resolution 0,01 °C
Humidity sensor accuracy
Typical absolute accuracy ±2 %, 20...80 %, 25 °C (only 3in1 and 4in1)
Pressure sensor accuracy
Main chip
Nordic Semiconductor nRF52832
Temperature sensor
Texas Instruments TMP117AIDRVR
Humidity sensor
Sensirion SHTC3 (4in1 and 3in1 only)
Pressure sensor
Infineon DPS310 (4in1 only)
Accelerometer
STMicroelectronics LIS2DH12
NFC
Embedded NFC™-A tag antenna
Enclosure material
Rugged polycarbonate
Waterproofing
IP67 (4in1 and 3in1), IP68 & IP69K (2in1)
Certifications
CE, FCC, ISED, TELEC, IFETEL, NOM, RTCA DO-160, RoHS, IP67, IP68, IP69K
Operating principle
Technical Operating Principle
The sensor measures and transmits data continuously every 2.5 seconds, regardless of whether an app is receiving the data. The app displays the data in real time when it is open. Since the real-time measurement data sent by the sensor is broadcast-type, multiple phones can read the sensor data simultaneously. To receive alerts on the phone, background scanning must be enabled in the app, and the phone must be within Bluetooth range. In the iOS app, to receive alerts when the app is in the background, two-way communication mode must be enabled. This is not required in the Android app.
Datalogger
RuuviTag Pro also functions as a data logger. The sensor continuously records temperature, humidity, and pressure data for the last 10 days at a five-minute recording interval. The internal history can be imported into the app when the phone is within Bluetooth range.
RuuviTag Pro Unboxing
Easy measuring
3 minute unboxing and setup
Watch
“We love the fully sealed version.”
Tens of thousands of happy customers in over 100 countries.
Rated 4.7/5 (Amazon)
"Accurate temperature monitoring is crucial to us"
Our business is to measure temperatures of food and medical transportations. The NIST traceable temperature sensor is a welcomed feature.
Ilkka, Finland
“We love the fully sealed version”
We measure only temperature and we need the sensors to survive outside in pretty rough conditions. These fully sealed versions are exactly what we've waited for.
Mike
"Very accurate in a dry sauna"
For my purposes, I see no need for improvement. I can say this guy works in temperatures up to at least 190°F (87.78°C) which makes it a good buy for saunas.
Michael Clendening, USA
"Easy to use"
Using product in a refrigerator and Freezer in my motorhome. Seems to be accurate and is lasting longer than some of the cheaper sensors I have tried in the past
Maggi, USA
"Works great with Victron"
We have a couple of these in our camper and they work great with the Victron Cerbo.
GB_Brad, USA
"Excellent sensor"
Great sensor for marine refrigeration. Bluetooth and accuracy are very good.
J. Moore, USA
"Very practical"
I have it installed in the compartment where the batteries are installed in a motorhome and perfect, it gives me the temperature whenever I request it. I am very happy with the purchase
Amazon Customer
“Avoided water damage”
I had a RuuviTag in my house’s boiler room. One day I noticed suddenly increased air humidity levels and went to see what’s going on. Found a leaking water pipe!
Pekka, Finland
"Easy install reasonable accuracy"
Search YouTube using "Victron Ruuvi". Watch a 5 minute video and set it up on a Cervo GX in less than 5 minutes as long as you don't have to update the Venus OS. It just works. There are a lot of videos stating the Ruuvi doesn't do Fahrenheit. I guess the old ones only did Celsius, but the new Ruuvi's have it.
Bill, USA
"Phenomenal product"
The Ruuvi is an excellent Bluetooth temperature sensor. Easy to setup an monitor.
Lyndsay, USA
All You Need is a Sensor and App
RuuviTag Pro sends measurements straight to your phone. The Ruuvi app is free and easy to use.
Ruuvi app features Ruuvi app features
Alerts, history and more
The Ruuvi Station app is user-friendly, allowing you to easily monitor sensor measurements and receive Bluetooth push notifications about any unexpected changes in conditions.
Personalise your Ruuvi mobile app
You can see the measurement results from the application when within Bluetooth range.
Temperature alarm in Ruuvi mobile app
Get alerted
You will receive a notification when conditions at the measurement location change beyond the limits you have set.
Temperature and humidity history graphs in Ruuvi mobile app
10-day history graphs
In the app, you can see the history of the past 10 days, even if you go out of Bluetooth range in between.
Temperature measurements in Ruuvi mobile app
Make it your own!
You can name your sensors, set a custom background image for them, and personalise the alert messages.
Download App
Ruuvi Station mobile app is available on Android and iOS.
Languages: English, Finnish, Swedish, French, and German.
Ruuvi products are ideal for both home and business use, and they are trusted by industry leaders.
Measure accurately in tough conditions
RuuviTag Pro, designed with high-quality components and the expertise of Finland’s finest engineers, is proudly made in Finland.
RuuviTag Pro Exploded Render
Durable
Withstands cold, heat, moisture, and impacts.
Wet-Certified
IP68 & IP69K in model 2in1, and IP67 in models 3in1 and 4in1.
Minimal maintenance
Battery life is 12-24 months with a user-replaceable battery CR2477T (included).
Wide operating temperature
Operating temperature range is -40°C to +85°C (-40°F to 185°F).
Wireless
Measurement results are sent directly to your phone wirelessly, within a Bluetooth range of 5-100 meters. *
Very accurate temperature sensor
Resolution: 0.01°C (0.018°F), absolute accuracy: ±0.1°C (±0.18 °F) *
Multiple sensors
Temperature, air humidity, air pressure, and motion, depending on the model.
Open Source
Ideal for business use as is, yet also customizable. Reliable and high-quality inside and out.
*When not within Bluetooth range, online remote monitoring is available with the Ruuvi Gateway router (sold separately).
*Across the temperature range of –20 to +50 °C (–4 to +122°F).
Mounting RuuviTag Pro 2in1 Temperature Sensor
Measure like a pro
RuuviTag Pro is the toughest open source sensor on the market.
Watch video
Medical Grade Temperature Accuracy
RuuviTag Pro has an extremely accurate temperature sensor on board. The sensor is designed to meet ASTM E1112 and ISO 80601 requirements for electronic patient thermometers.
Measurement resolution is 0,01 °C, while absolute accuracy is astounding at ±0,1 °C across the temperature range of –20 to +50 °C, with no calibration.
The sensor units are 100% tested on a production setup that is NIST traceable and verified with equipment that is calibrated to ISO/IEC 17025 accredited standards.
Note! Individual calibration certificates are not available.
Wet-Certified
RuuviTag Pro tolerates wet and rough conditions.
The IP67 certified RuuviTag Pro (4in1 and 3in1) comes with a breathable membrane that enables air humidity and air pressure monitoring. It tolerates temporary wet conditions and it’s a good choice to outdoor use. The 4in1 and 3in1 models are for non-condensing uses only.
The IP68 and IP69K certified RuuviTag Pro (2in1) offers a full protection against water with its fully sealed enclosure.
Note! Please keep in mind that Bluetooth signals are strongly attenuated in the water and range will be significantly reduced. Due to very limited range it’s usually not practical to use sensor underwater. If you want to measure deeper, you can attach the RuuviTag Pro to a string and take it back to the surface when you want to download the data history.
Temperature sensors in every room at home Temperature sensors in every room at home
What to measure?
Ruuvi sensors have hundreds of use-cases where measuring conditions and enabling automatic alerts make your life more worry-free. Read more below:
Home
Using Ruuvi Sensors at Home
By using RuuviTags to measure the temperature and humidity in different rooms, you gain a comprehensive understanding of your home’s functionality and health. This not only helps you save energy but also allows you to live more comfortably and worry-free.
Outside
By measuring outdoor conditions as well, you gain a better understanding of how your home behaves in different weather. RuuviTag serves as the ideal real-time weather station for your own yard.
Bedroom
Sleep Quality
Ensure optimal sleeping conditions by maintaining appropriate temperature and humidity levels, preventing sleep disturbances and improving overall health.
Ideal bedroom temperatures are between 16°C and 20°C (60°F and 68°F) with humidity levels between 30% and 50%. This prevents poor sleep quality and respiratory issues from dry air or excessive humidity.
Bathroom
Mold Prevention and Energy Efficiency
Monitor humidity to prevent mold and mildew growth, which can lead to health issues and structural damage. Optimizing underfloor heating can prevent high electricity bills.
Keep bathroom humidity levels below 60%, ideally between 40% and 50%. Temperatures should be around 21°C to 24°C (70°F to 75°F). The floor surface temperature should be between 23°C and 24°C (73°F and 75°F). This prevents mold, mildew, and structural damage, and helps manage electricity costs.
Garage
Temperature and Humidity Control
Maintain optimal conditions to prevent damage to stored items and protect water pipes from freezing.
Suggested garage temperatures are at least 5°C (41°F), preferably between 12°C and 15°C (54°F and 59°F). It doesn’t need to be above 0°C (32°F) if the relative humidity is low enough. Avoid subzero temperatures if there are water pipes at risk of freezing. Keep in mind that the temperature can vary significantly (even by more than 10°C/50°F) between the floor and the ceiling.
Fridge/Freezer
Optimal Temperature and Storage Conditions
Ensure proper temperature settings to maintain food safety and maximize appliance efficiency.
For refrigerators, the ideal temperature range is between 2°C and 5°C (36°F and 41°F) to keep food fresh and safe from spoilage. Freezers should be set at -18°C (0°F) or lower to properly store frozen goods. It’s important to avoid temperatures above 5°C (41°F) in the fridge, as this can promote bacterial growth, and above -18°C (0°F) in the freezer, which may lead to food quality degradation.
Livingroom
Comfort and Energy Efficiency
Monitor temperature and humidity to maintain a comfortable environment while optimizing heating and cooling systems, reducing high energy costs.
Ideal living room temperatures range from 20°C to 22°C (68°F to 72°F) with humidity levels between 30% and 50%. This prevents high energy costs and discomfort from temperature extremes.
Kitchen
Food Storage and Cooking Comfort
Monitor temperature to ensure proper storage conditions for food and maintain a comfortable environment while cooking, preventing food spoilage and bacterial growth.
Keep kitchen temperatures around 18°C to 22°C (64°F to 72°F) with humidity levels between 40% and 60%. This prevents food spoilage and bacterial growth.
Nursery
Infant Comfort and Healt
Ensure optimal temperature and humidity for the health and comfort of infants, reducing the risk of SIDS and respiratory problems.
Ideal nursery temperatures are between 20°C and 22°C (68°F and 72°F) with humidity levels between 30% and 50%. This prevents respiratory problems and reduces the risk of SIDS.
Basement
Moisture Control and Storage
Monitor for moisture to prevent mold and maintain proper conditions for stored items, preventing property damage and health issues.
Maintain basement humidity levels between 30% and 50% to prevent mold. Temperatures should be kept between 15°C and 20°C (59°F and 68°F). This prevents mold, mildew, and property damage.
Attic
Heat Regulation
Monitor temperature to prevent overheating and ensure proper ventilation, avoiding structural damage and high energy costs.
Attic temperatures should ideally not exceed 40°C (104°F) to prevent damage and maintain structural integrity. Humidity levels should be kept low, between 30% and 50%. This prevents structural damage and high energy costs.
Home Office
Comfort, Efficiency, and Equipment Safety
Maintain a comfortable working environment, enhance efficiency, and protect electronic equipment from overheating and humidity, preventing equipment failure and discomfort.
Ideal temperatures for a home office are between 20°C and 22°C (68°F and 72°F) with humidity levels between 30% and 50%. This range not only prevents equipment failure and discomfort but also promotes optimal working efficiency by avoiding temperature extremes.
Closet and Storage Spaces
Clothing and Item Preservation
Monitor humidity to prevent mold and mildew on clothing and stored items, avoiding damage and preserving quality.
Keep humidity levels in closets and storage spaces between 30% and 50%. Temperatures should be around 18°C to 22°C (64°F to 72°F). This prevents mold, mildew, and damage to clothing and items.
Hobbies
Motorhomes, caravans, boats
Environmental Monitoring
Keep track of temperature and humidity in motorhomes or RVs to ensure a comfortable living environment and protect perishable items. Monitor fridge temperatures to prevent food spoilage and ensure safety. Additionally, track battery compartment conditions to maintain optimal performance and prevent damage from extreme temperatures or humidity.
Maintain the interior of motorhomes at temperatures between 18°C and 24°C (64°F and 75°F). Fridges should be kept between 1°C and 4°C (34°F and 39°F), and battery compartments should be monitored to stay within the operational range of -20°C to +50°C (-4°F to 122°F).
Dogs, cats, indoor pets
Temperature Monitoring
Monitor temperature in living spaces to prevent heatstroke or hypothermia and maintain a healthy environment for pets, especially when traveling or during extreme weather conditions.
Humidity Monitoring
Prevents respiratory discomfort and skin issues.
Ideal indoor temperatures for pets range from 18°C to 24°C (64°F to 75°F). Humidity levels should be maintained between 30% and 70% to ensure their comfort and health.
Gardening
Plant Growth
Monitor and adjust temperature and humidity to create optimal growing conditions for plants, both indoors and in greenhouses, enhancing yield and quality.
Most plants thrive at temperatures between 18°C and 24°C (64°F and 75°F). Relative humidity should be between 40% and 80%. The temperature should not rise above 26°C (79°F).
Root Cellar and Food Storage
Food Preservation
Maintain optimal conditions in a root cellar to store harvested produce, ensuring freshness and preventing spoilage.
Root vegetables like carrots and potatoes are best stored at temperatures between 0°C and 4°C (32°F and 39°F) with humidity levels around 85%-95%. Other produce, such as apples, should be stored at slightly higher temperatures around 1°C to 3°C (34°F to 37°F) with similar humidity levels.
Reptile Keeping
Terrarium Monitoring
Ensure the proper environment for reptiles by maintaining specific temperature and humidity levels for their health and well-being.
Reptiles like bearded dragons thrive at temperatures between 24°C and 35°C (75°F and 95°F) with a humidity level of 20%-40%.
Wine Collecting
Cellar Management
Maintain ideal storage conditions in wine cellars by controlling temperature and humidity to preserve the quality and taste of wine.
Wine should be stored at a consistent temperature of around 12°C to 14°C (53°F to 57°F) with a humidity level between 60% and 70%.
Home Brewing
Fermentation Control
Maintain optimal temperature and humidity for fermenting beverages, ensuring quality and preventing spoilage.
Most ales ferment best at temperatures between 18°C and 22°C (64°F and 72°F), while lagers require cooler temperatures between 7°C and 13°C (45°F and 55°F). Humidity levels should be kept low to prevent mold growth.
Baking
Dough Proofing
Ensure the ideal environment for proofing bread and other baked goods by controlling temperature and humidity levels.
Ideal proofing temperatures range between 21°C and 27°C (70°F and 80°F) with a humidity level of around 75%.
Cigar Collecting
Humidor Management
Keep cigars in perfect condition by maintaining the correct temperature and humidity levels in humidors.
Cigars should be stored at temperatures around 18°C to 20°C (64°F to 68°F) and a relative humidity of 65%-72%.
Travelling and Remote Monitoring
By purchasing a Ruuvi Gateway router and Ruuvi Cloud service along with your RuuviTags, you can access your sensors online and gather long-term history to your account. With Ruuvi Gateway, you can also share your sensors with your family.
Business
RuuviTags in Business Use
RuuviTags (and RuuviTag Pros) have already found their way into thousands of companies worldwide. Ruuvi’s open-source sensors are customisable, fully certified, and available in large quantities.
“Ruuvi is an impressive sensor technology company that consistently outperforms its at times much larger competitors in terms of quality, ease of use, innovation and customer service.”
– Ole Johan A. Bjerke, CEO and co-founder of Soundsensing
“We have comprehensive temperature monitoring with Ruuvi, meeting regulatory requirements. Ruuvi’s products are remarkably user-friendly, and we are extremely satisfied!”
– Harri Nykopp, K-retailer, K-Market Otso
Grocery Stores and Supermarkets
Cold Storage
Monitor refrigerators and freezers to ensure perishable items are stored at safe temperatures.
Produce Sections
Track humidity levels to keep fruits and vegetables fresh.
Restaurants and Food Service
Kitchens
Maintain proper storage conditions for ingredients in walk-in coolers and freezers.
Dining Areas
Ensure comfortable dining environments by monitoring temperature and humidity.
Pharmaceuticals and Healthcare
Drug Storage
Control temperature and humidity to ensure the safety and efficacy of medications and vaccines.
Medical Facilities
Maintain optimal conditions in laboratories and patient care areas.
Agriculture
Greenhouses
Optimize growing conditions by monitoring temperature and humidity.
Crop Storage
Prevent spoilage and maintain quality in storage facilities.
Manufacturing
Electronics
Protect sensitive components by controlling humidity levels.
Food and Beverage Production
Ensure compliance with health regulations and maintain product quality.
Museums and Archives
Preservation
Prevent deterioration of artifacts, documents, and artworks by maintaining controlled environments.
Data Centers
Environmental Control
Ensure the reliability and performance of IT equipment by maintaining optimal conditions.
Logistics and Cold Chain Management
Transportation
Monitor conditions during the transport of sensitive items to ensure they remain within safe parameters.
Wine Storage
Cellars and Warehouses
Preserve the quality and taste of wine by maintaining ideal temperature and humidity levels.
HVAC Systems
Building Management
Optimize HVAC systems for energy efficiency and maintain comfortable indoor environments.
Order Now
Choose the best option for you.
    Read more
    55,90
    Read more
    Read more
The more you order, the more you save! Watch the price drop as you add more items.
Get hooked on Ruuvi Sensors!
You can find plenty of user materials about Ruuvi online. Don’t forget to share your experience too! #ruuvitag @ruuvicom
Join Ruuvi-related discussions on our channels:
Telegram | Forum
Proudly Open Source
Ruuvi sensors are open source, meaning their design and code are not hidden. This allows you to use Ruuvi sensors as a foundation for personal tech projects or for companies to incorporate them into their product development. Ruuvi sensors can also be used as-is in your own projects or business operations.
We encourage business customers to visit our Business website.
Join Our Tech Community
Ruuvi’s community has always been filled with talented hobbyists and developers. On our blog and documentation pages, you’ll find a wealth of interesting tech-related content and information. If you want to dive deeper into integrations, you can explore them here. Join the community discussions on Ruuvi’s Forum and Telegram.
What are the differences between RuuviTag and RuuviTag Pro?
RuuviTag Pro has several new features such as:
  • High accuracy temperature sensor
  • Wide operating temperature range
  • IP67, IP68 and IP69K certifications
  • Professional mounting
  • Industrial design
  • Optional expansion port
  • Sensor configuration depends on the model
What are the differences between the IP67, IP68 and IP69K in RuuviTag Pro?
RuuviTag Pro has been professionally laboratory tested and certified for IP67, IP68 and IP69K.
IP67 tolerates wet condition only temporarily. It can be used outside as long as the breathing membrane will not stay wet more than 30 minutes.
IP68 certification ensures that RuuviTag Pro will function in water for 24 hours.
IP69K means that the unit has undergone a challenging set of tests to ensure that it offers protection against penetration of high pressure and high temperature water of 80 °C.
Why would I need Ruuvi products?
The use cases for Ruuvi sensors are unlimited and the only limit is your imagination. Read more about use cases and user experiences on our blog and our forum.
The Ruuvi products are designed in Finland and produced in France with the highest quality standards to ensure the best possible products at the end!
We do not believe in bots (at least on our webpage)! We are very happy to answer any of your questions regarding a product or to support you with any issue.
Why are there two enclosure models in RuuviTag Pro?
RuuviTag Pro’s fully sealed version is IP68 and IP69K certified. This means that it tolerates wet conditions like never seen before.
The IP67 model has a weather resistant membrane that allows air to pass through. This is a requirement to allow you to measure air humidity and air pressure.
What sensors are included in RuuviTag Pro?
RuuviTag Pro has three models:
  • Fully sealed 2in1 version that measures temperature and motion
  • Breathable 3in1 model that measures temperature, humidity and motion
  • Breathable 4in1 version that measures temperature, humidity, air pressure and motion
Please read the technical specifications for more details before ordering.
What is included in the product package of RuuviTag Pro?
  • RuuviTag Pro
  • Quick start guide
  • Mounting screws
Is my mobile device compatible with Ruuvi products?
Ruuvi’s sensors work with Ruuvi Station mobile app. The app can be downloaded both from the Play Store (Android) and the App Store (iOS). It is also available for tablets.
How to monitor the Ruuvi sensors remotely?
The Gateway is connected to the internet and listens to sensors with a higher sensitivity than a regular mobile device. The test results talk by themselves: up to 2000 meters between the Gateway and the sensors, compared to 200 meters between a mobile device and the sensors (test realized in optimal conditions without any obstacle).
Do I need to charge my Ruuvi sensors?
No, the power of the RuuviTag Pro sensors is supplied by CR2477T coin batteries, included in the box. One battery lasts usually between 2 to 3 years in continuous use. The battery is easily replaceable by the user making our products very sustainable and lowering their maintenance costs to a few euros every two years.
Check how to change the RuuviTag Pro battery!
Can I use the Ruuvi sensors to monitor my sauna?
Yes you can!
The sensor’s temperature increases slightly slower than the sauna’s temperature and the readings depend a lot on where it is placed inside the sauna. But that’s not a problem! Just check at the first use what is the sensor reading when the sauna is just perfect for you. Then, set the alert to this specific value to get notified when the sauna is ready and to get the perfect temperature every single time!
Please note, that if the sensor is reaching temperatures above 85°C you should consider setting the sensor somewhere lower in the sauna to avoid any thermal damage.
What is the range?
Using only Ruuvi sensors
The sensors send data packages via Bluetooth to your mobile device. Thanks to optimized sensor antenna design, in perfect conditions without any obstacle, the Bluetooth range is up to 200 meters, which is way more than that regular Bluetooth speaker.
Are Ruuvi products compatible with a home assistant?
The Ruuvi products are not directly integrated into home automation systems. However, all our products are open-source and can be integrated to any home automation system, requiring some further development. Discussions and tutorials about the topic are available on our forum.
How fast is the shipping?
We work with the best courier partners and do our best to proceed to the shipment within 24 hours from the order! All the products are sent from our warehouse in Finland and delivery time depends obviously on your location. We will provide you with a tracking number automatically to your email so that you can follow where your Ruuvi package is going.
Can I see the data history of my Ruuvi sensors?
Yes you can!
Up to 10 days with the Ruuvi sensors alone
The Ruuvi sensors have built-in storage enabling them to store 10 days of measurement data. You can import the data to the Ruuvi Station mobile app at any point by pressing “sync” button in the app. This means that even when leaving from the Bluetooth range, you will be able to see a detailed 10 days history when coming back and synchronizing.
Up to 2 years with the Ruuvi Gateway and our cloud service
If this 10 days of data is too short, or that you want to be able to monitor your sensors remotely, you should consider the Ruuvi Gateway. It enables you to analyze up to 2 years of data history on the convenient and intuitive desktop version of Ruuvi Station. Also, no need to synchronize, the Ruuvi Gateway is continuously sharing data to the cloud and it is retrievable from anywhere around the world as long as you have an internet connection.
