App Settings: Language
Ruuvi Station is currently fully translated to English, German, French, Swedish and Finnish. If you choose a language that the app hasn’t been translated to yet, the English language will be used. Language selection works slightly differently in Ruuvi Station mobile apps (iOS/Android) and Ruuvi Station web app.
Change the language in Ruuvi Station iOS mobile app
 You will choose App language, which can be different from operating system language.
To change this OS setting, go to Settings – Ruuvi Station – Preferred language – Language.
Note: If you cannot see the Language option in settings, make sure that you have at least one preferred language added in system settings: Settings – General – Language & Region.
Change the language in Ruuvi Station Android mobile app
Depending on your Android OS version you will either:
1. Choose the operating system language which will be reflected everywhere in the Android operating system (OS12 and lower).
To change this OS setting, go to Settings – General Management – Language.
2. Choose App language, which can be different from operating system language (OS13 and higher).
Change the language in Ruuvi Station web app
You will choose the web app language. This setting is only reflected in Ruuvi Station web app.
To change the web app language, go to Settings Menu – Settings – Language.
