History view: Scan Interval In Ruuvi Station
Ruuvi Station mobile app
Ruuvi Station mobile app scans and updates sensor values in the app according to various set intervals. History view is able to show the measurement history for a maximum of 10 days on the Ruuvi Station mobile app.
By default, the mobile app uses your device’s Bluetooth connection to listen for sensor broadcasts. RuuviTag sensors actively send broadcasts every 2.5 seconds while Ruuvi Air sensors broadcast once every second.
Ruuvi Station mobile app can receive data from Ruuvi sensors in several ways: directly via Bluetooth, through the Ruuvi Cloud (requires Ruuvi Gateway router), or both.
Intervals when using Bluetooth data source on mobile devices
Foreground scanning interval (mobile app): RuuviTag sensors broadcast every 2.5 seconds, Ruuvi Air sensors once every 1 second and the app attempts to update collected data continuously while running in the foreground, providing real-time updates.
Background scanning interval (mobile app): Enable background scanning and set an interval in the Ruuvi Station mobile app setting to collect data over Bluetooth while the app is minimised.
Background data logging interval can be adjusted between All and 60 minutes in the app settings. Longer intervals reduce battery consumption while maintaining periodic data collection.
Synchronise internal memory from sensor (mobile app): Ruuvi sensors can store up to 10 days of measurement data, which you can download via your mobile device Bluetooth connection using the synchronise feature in the history view page in Ruuvi Station mobile app. Internal memory logging uses 5 minute intervals.
Ruuvi Station web app
Ruuvi Station Web app updates collected sensor values according to your Ruuvi Cloud subscription level. History view is able to show the measurement history for up to 3 years on the Ruuvi Station web app, depending on your subscription level. Using the Ruuvi Station web app requires a Ruuvi Gateway router
Intervals when using Cloud data source
Cloud sync interval (mobile and web): Requires a Ruuvi Gateway router. The Ruuvi Gateway router listens to local sensor broadcasts and sends the collected data to the Ruuvi Cloud.
When signed in to the Ruuvi Station mobile app, up to 10 days of sensor measurement history stored in the cloud is synced to the app at intervals set by your Ruuvi Cloud subscription plan
When using the Ruuvi Station web app, the length of sensor measurement history available (up to 3 years), and the update interval for the latest values depend on your Ruuvi Cloud subscription plan.
These intervals cannot be adjusted in the app.
