Monitor Your Home
With RuuviTag, you can remotely monitor temperature, humidity, and air pressure levels in your home and other properties.
Tax 25,5% | 0%
95%
5%
0%
0%
0%
1-15 of 61 reviews
Technical Specifications
Product package
-20 ºC to +70 ºC (with a special temperature range battery longer battery lifetime can be achieved)
Maximum operating temperature
Battery
Diameter
52,00 mm
Height
12,55 mm
Weight
30 g
Celsius, Fahrenheit, Kelvin
Pa, hPa, mmHg, inHg
Temperature sensor accuracy
Humidity sensor accuracy
Pressure sensor accuracy
Main chip
Nordic Semiconductor nRF52832
Ambient sensor
Pressure sensor
Infineon DPS310
Accelerometer
STMicroelectronics LIS2DH12
Radio protocols
NFC
Embedded NFC™-A tag antenna
Enclosure material
Polycarbonate
Waterproofing
Certifications
CE, FCC, ISED, TELEC, IFETEL, NOM, RTCA DO-160 category H, RoHS, IC, HVIN, IMDA, OFCA, ICASA, POTRAZ
FREE
SHIPPING
For orders over 120 €.
MADE IN
EUROPE
Made in Finland.
SATISFIED
USERS
Return rate < 0,1 %.
QUICK
SUPPORT
Fast and friendly support.
Wireless and
Weatherproof
Ideal for monitoring your home
Temperature and Humidity Monitoring Made Easy
RuuviTag is a wireless Bluetooth sensor node that measures temperature, air humidity, air pressure and movement, offering an endless amount of use cases around the home. With RuuviTag you can monitor and optimise the conditions in your home and other properties.
Most Common Questions
Under what type of weather conditions can the RuuviTag function?
Temperature
Electronics of the Ruuvi sensors can support temperatures between -40°C (-40°F) and +85°C (+185°F). However, the market standard CR2477 batteries’ operation range is usually between -20°C (-4°F) and +70°C (+158°F). Do not exceed these temperatures without shopping our custom made wide-range battery, which is designed to operate with the same limits as the electronics of the sensors.
Dust & Water
All the sensors are resistant to dust and moisture. Some of the sensors are IP67 certified (water-resistant) and some are IP68 or IP69K certified (waterproof). See the specific certifications for each sensor on the product page. Please keep in mind that water lowers drastically the range of the sensors.
What is the Bluetooth range?
Using only Ruuvi sensors
The sensors send data packages via Bluetooth to your mobile device. Thanks to optimized sensor antenna design, in perfect conditions without any obstacle, the Bluetooth range is up to 200 meters, which is way more than that regular Bluetooth speaker.
Can I monitor from anywhere?
The Gateway is connected to the internet and listens to sensors with a higher sensitivity than a regular mobile device. The test results talk by themselves: up to 2000 meters between the Gateway and the sensors, compared to 200 meters between a mobile device and the sensors (test realized in optimal conditions without any obstacle).
Do I need to charge my Ruuvi sensors?
No, the power of the Ruuvi sensors is supplied by CR2477 coin batteries, included in the box. One battery lasts usually between 2 to 3 years in continuous use. The battery is easily replaceable by the user making our products very sustainable and lowering their maintenance costs to a few euros every two years.
Will RuuviTag work with my phone?
The Ruuvi Station app can be downloaded both from the Play Store (Android) and the App Store (iOS). It is also available for tablets.
"Easy remote monitoring"
I use the RuuviTag to monitor the conditions of our cottage when we're not there. It's the most convenient way I've found to monitor safe temperature and humidity
“Abnormal tempereture detected”
I received an alarm from Ruuvi Station on my phone saying "temperature too low". A window was broken during winter, and were able to fix it before any major damage.
“Really useful accessories”
I like to use the RuuviTag holder, it is 100% impossible for my pets to have access to the sensor or to inadvertently eat it.
Get your own!
Click the button below to scroll to top and make an order.
Excellent!
Battery Box
Engel Fridge
Main Rapido Fridge Area
I have now configured:
High temperature alarms
Low temperature alarms
VRM email notifications
the battery box overheats
