Sensor Settings: Offset correction
Ruuvi sensors can be calibrated by using offset correction. Offset will correct received measurements in Ruuvi Station app by specified value and will reflect on sensor cards as well as history view and in csv file export.
Calibrated sensor values will be used when a specific sensor with offset correction setting is shared to a Ruuvi Cloud user by using Sensor Sharing feature (requires Ruuvi Gateway router).
In mobile, offset correction can be set under Sensor Settings.
In web, offset correction can be set in full sensor card.
Offset correction is available for temperature, humidity and pressure values.
Humidity correction can only be set using relative humidity (%) unit values.
Notice! Offset correction can be set for local Bluetooth sensors. Alternatively offset can be set by sensor owners for sensors that have been added to a Ruuvi account.
