Wireless Bluetooth Sensor
With RuuviTag, you can monitor temperature, humidity, and air pressure levels.
4.9 76 reviews
Tax 25,5% | 0%
Total : 39,90€ + shipping
Technical Specifications
Product package
-20 ºC to +70 ºC (with a special temperature range battery longer battery lifetime can be achieved)
Maximum operating temperature
Battery
Diameter
52,00 mm
Height
12,55 mm
Weight
30 g
Celsius, Fahrenheit, Kelvin
Pa, hPa, mmHg, inHg
Temperature sensor accuracy
Humidity sensor accuracy
Pressure sensor accuracy
Main chip
Nordic Semiconductor nRF52832
Ambient sensor
Pressure sensor
Infineon DPS310
Accelerometer
STMicroelectronics LIS2DH12
Radio protocols
NFC
Embedded NFC™-A tag antenna
Enclosure material
Polycarbonate
Waterproofing
Certifications
CE, FCC, ISED, TELEC, IFETEL, NOM, RTCA DO-160 category H, RoHS, IC, HVIN, IMDA, OFCA, ICASA, POTRAZ
FREE
SHIPPING
For orders over 120 €.
MADE IN
EUROPE
Made in Finland.
SATISFIED
USERS
Return rate < 0,1 %.
QUICK
SUPPORT
Fast and friendly support.
Measure outdoor temperature remotely
Smart
Home Measuring
Four environmental sensors in one tag.
Smart Wireless Bluetooth Sensors
RuuviTag is a wireless Bluetooth sensor that measures temperature, air humidity, air pressure and movement, offering an endless amount of use cases. You can read live measurements and historical data directly on your smartphone using Ruuvi’s mobile app for Android and iOS. You can also monitor sensors remotely with Ruuvi Gateway product.
Easy to use
1 minute quick start
Multiple sensors
Multiple sensors in one device
Multi-year battery lifetime
FREE mobile application
Most common questions
What is a wireless Bluetooth sensor?
Wireless Bluetooth Sensor beacons are small transmitters that broadcast environmental data signals to close portable devices using Bluetooth Low Energy technology. RuuviTag is a wireless Bluetooth sensor that measures temperature, air humidity, air pressure and movement.
How do you use a wireless Bluetooth sensor?
You can read live measurements and historical data directly on your smartphone using wireless Bluetooth connection. It’s not necessary to pair sensor to mobile phone. Ruuvi has a mobile app for Android and iOS.
What is the Bluetooth range?
Ruuvi sensors send data packages via Bluetooth to your mobile device. Thanks to optimized sensor antenna design, in perfect conditions without any obstacle, the Bluetooth range is up to 200 meters, which is way more than that regular Bluetooth devices.
How do the Ruuvi products actually work?
The Ruuvi product portfolio is made of:
Ruuvi sensors
The Ruuvi sensors measure air temperature, humidity, pressure, and acceleration, depending on the models. More precise specifications are provided on the product page. They send the data via Bluetooth either to the Ruuvi Gateway or to the Ruuvi Station mobile app.
Ruuvi Station App
The Ruuvi Station app can be downloaded for free both from the Play Store (Android) and the App Store (iOS). It displays the measurements received from the Sensors. In the app, it is possible to read history graphs, set alerts with customizable parameters, and much more!
A web interface is also available when using our cloud service.
Ruuvi Gateway
The Gateway is our solution for remote monitoring, check how to it works on this page.
Accessories
You will also find all the accessories that you might need from stands to replacement batteries in the “all products” section of our website.
What are the operating conditions of the Ruuvi sensors?
Temperature
Electronics of the Ruuvi sensors can support temperatures between -40°C (-40°F) and +85°C (+185°F). However, the market standard CR2477 batteries’ operation range is usually between -20°C (-4°F)  and +70°C (+158°F). Do not exceed these temperatures without shopping our custom made wide-range battery, which is designed to operate with the same limits as the electronics of the sensors.
Dust & Water
All the sensors are resistant to dust and moisture. Some of the sensors are IP67 certified (water-resistant) and some are IP68 or IP69K certified (waterproof). See the specific certifications for each sensor on the product page. Please keep in mind that water lowers drastically the range of the sensors.
How to monitor the Ruuvi sensors remotely?
The Gateway is connected to the internet and listens to sensors with a higher sensitivity than a regular mobile device. The test results talk by themselves: up to 2000 meters between the Gateway and the sensors, compared to 200 meters between a mobile device and the sensors (test realized in optimal conditions without any obstacle).
Monitor temperature remotely
Set
custom
alerts
Set parameters and receive notifications during abnormal conditions.
Smart greenhouse temperature and humidity alerts
Optimize room temperature on summer
Temperature
RuuviTag works in both cold and hot environments, enabling users to measure temperature in the most demanding and harsh conditions, ranging from -40°C to +85°C (with a special battery).
Historical data
Music room temperature
Humidity
With RuuviTag you can measure and respond to changes in air humidity in real-time. Range: 0-95%.
Music room humidity measurements with smart sensor
"Avoided water damage"
I had a RuuviTag in my boiler room. One day I noticed increased air humidity levels and went to see what was going on. Found a leaking water pipe
Mike, 47
“Mounting is easy and quick”
The RuuviTag is very easy and simple to mount and get started with the mobile app in minutes
Pekka, 57
“Useful history logs”
The extended 7 days history logs was a great update.
Stefan, 33
Get your own!
Click the button below to scroll to top and make an order.
