Integrates with Cerbo GX, GlobalLink 520, and Ekrano GX.
Set alerts, create automations, and more in Victron VRM or in Victron app. Perfect for Boats, RVs, and Off-Grid Living:
Engine room & battery compartment monitoring | Cockpit & cabin comfort | Food storage safety | Mold & corrosion prevention | Fridge/freezer & pet safety | Water pipe freeze prevention | Outdoor weather tracking | And more…
Tens of thousands of happy customers in over 150 countries.
4.4/5 star customer rating | Made in Finland | CE/FCC/ISED certified | Open source | Victron Compatible
These @ruuvicom products are simply the best temperature and condition meters I have ever used. I have over 20 of them, both personally and at work. I give them a 5/5 rating. A special shout-out to the excellent customer service and for being manufactured in Europe.
I’ve been using 4 of these senors on our sailboat for temperature in fridge, freezer, engine room, generator sound enclosure, and the pro-model as a water alarm in our bilge for almost a year now. They also easily paired with our Victron systems and the setup was unbelievably easy. I can not recommend them enough. A 10 out of 5.
Using product in a refrigerator and Freezer in my motorhome. Seems to be accurate and is lasting longer than some of the cheaper sensors I have tried in the past
Bought three of these to measure fridges on my boat. I like how easy they are to set up and how reliable they have been. The batteries are supposed to last a long time so that is great too. Expensive, but well worth it in my opinion.
As Ordered - Love the Ruuvi Sensors - 8 of them tell me when to turn off the fans and shut the window
An excellent product, the temperature measurement is very accurate.
I have it installed in the compartment where the batteries are installed in a motorhome and perfect, it gives me the temperature whenever I request it. I am very happy with the purchase
I had a RuuviTag in my house’s boiler room. One day I noticed suddenly increased air humidity levels and went to see what’s going on. Found a leaking water pipe!
Search YouTube using "Victron Ruuvi". Watch a 5 minute video and set it up on a Cervo GX in less than 5 minutes as long as you don't have to update the Venus OS. It just works. There are a lot of videos stating the Ruuvi doesn't do Fahrenheit. I guess the old ones only did Celsius, but the new Ruuvi's have it.
The Ruuvi is an excellent Bluetooth temperature sensor. Easy to setup an monitor.
Effortlessly enhance your Victron Energy system with Ruuvi wireless sensors and gain instant peace of mind.
| 5 star | 0% | |
| 4 star | 0% | |
| 3 star | 0% | |
| 2 star | 0% | |
| 1 star | 0% |
Sorry, no reviews match your current selections
Made in Europe, Finland. Worldwide free shipping on orders over 120 €.
Platforms: Android and iOS.
Data sheet: Download (pdf)
Read more info below:
For orders over 100 €.
Designed and
manufactured in Finland
Our return rate is
less than 0,1 %.
Fast response time
to all messages.
The more you order, the more you save! Watch the price drop as you add more items.
Check out the list of authorized Ruuvi Resellers, all over the world!
Order RuuviTag sensors for Victron today and experience effortless, reliable environmental monitoring. Wherever your journey takes you.
Yes! Works with Cerbo GX, GlobalLink 520, and Ekrano GX.
Yes, via Victron VRM or with Ruuvi Gateway and Ruuvi Cloud.
Victron has integrated RuuviTag sensor compatibility into Venus OS 2.80, allowing your RuuviTag sensors to be added to supported systems like the Cerbo GX monitoring system, and it’s predecessors the Color Control GX, Venus GX and more.
However, the Cerbo GX’s built-in Bluetooth radio is not reliable enough to work with Ruuvi sensors. As a result, Victron advises installing a Bluetooth 4.0 USB adapter when using Cerbo GX with RuuviTag sensors.
A list of tested adapters is available here. The main concern is related to internal temperature, which means the system may function without problems in colder conditions. Nonetheless, for best performance and reliability, using a recommended Bluetooth adapter is advised.
More information about RuuviTag and Victron integration can be found here!
The use cases for Ruuvi sensors are unlimited and the only limit is your imagination. Read more about use cases and user experiences on our blog and our forum.
The Ruuvi products are designed in Finland and produced in France with the highest quality standards to ensure the best possible products at the end!
We do not believe in bots (at least on our webpage)! We are very happy to answer any of your questions regarding a product or to support you with any issue.
RuuviTag is IP67 certified (water-resistant, tested in 1 meter depth). If you are looking for a fully waterproof sensor, please check out RuuviTag Pro (2in1), which is IP68 or IP69K certified (waterproof, tested in 50 meters depth). See the certification of each sensor directly on the product pages.
Please keep in mind that Bluetooth signals are strongly attenuated in the water and range will be significantly reduced. Ruuvi sensors can then be used in narrow water if you want to maintain connection (for example pool or jacuzzi). If you want to measure deeper, you can attach the RuuviTag Pro to a string and take it back to the surface when you want to download the data history.
Temperature
Electronics of the Ruuvi sensors can support temperatures between -40°C (-40°F) and +85°C (+185°F). However, the market standard CR2477 batteries’ operation range is usually between -20°C (-4°F) and +70°C (+158°F). Do not exceed these temperatures without shopping our custom made wide-range battery, which is designed to operate with the same limits as the electronics of the sensors.
Dust & Water
All the sensors are resistant to dust and moisture. Some of the sensors are IP67 certified (water-resistant) and some are IP68 or IP69K certified (waterproof). See the specific certifications for each sensor on the product page. Please keep in mind that water lowers drastically the range of the sensors.
No, the power of the Ruuvi sensors is supplied by CR2477 coin batteries, included in the box. One battery lasts usually between 1-2 years in continuous use. The battery is easily replaceable by the user making our products very sustainable and lowering their maintenance costs to a few euros every two years.
Using Ruuvi sensors with Victron Cerbo GX
It’s recommended to use external Bluetooth dongle with Victron Cerbo GX to ensure reliable Bluetooth reception. Recommended Bluetooth dongles can be found here.
Using only Ruuvi sensors
The sensors send data packages via Bluetooth to your mobile device. Thanks to optimized sensor antenna design, in perfect conditions without any obstacle, the Bluetooth range is up to 200 meters, which is way more than that regular Bluetooth speaker.
We work with the best courier partners and do our best to proceed to the shipment within 24 hours from the order! All the products are sent from our warehouse in Finland and delivery time depends obviously on your location. We will provide you with a tracking number automatically to your email so that you can follow where your Ruuvi package is going.
