Video: Ruuvi Gateway Quick Start
1. Connect Ruuvi Gateway to the Internet
Ethernet
Wired Ethernet connection offers the most reliable Internet connectivity. We suggest using it whenever available. To use an Ethernet connection, just connect your Ruuvi Gateway to your Internet router with an Ethernet cable and power up the Gateway using a power supply. That’s it! Now you can proceed to step 2.
Wi-Fi
If you prefer to use Wi-Fi, first connect the Gateway to a power source. A new Wi-Fi hotspot will appear:
Wi-Fi hotspot: Configure Ruuvi Gateway
Connect to the Wi-Fi hotspot using your mobile or desktop device. The configuration page should open automatically. If not, open your browser and go to 10.10.0.1, then follow the instructions to connect to Wi-Fi.
WPS option: For a quick setup, press the WPS button on your router after powering the Gateway. The connection will establish automatically.
Notice: If your device has been on for an extended period, the Wi-Fi hotspot may no longer be active. To reactivate it, use a paperclip to briefly press the keyhole button located beneath the USB-C port.
2. Claim your sensors on the Ruuvi Station mobile app
Ruuvi Gateway is now functional and it’s continuously routing nearby sensors’ data securely to the Ruuvi Cloud. Only you can access the data of the sensors owned by you. Each sensor can have only one owner.
Now, let‘s tell the cloud which sensors are owned by you.
- Sign in on the mobile application, if you haven’t signed in yet.
 - Add your sensor on the app, if you already haven’t added it.
 - Go to sensor’s settings page and tap “Owner”. Claim the ownership.
Note! If you don’t claim ownerships of your sensors, you cannot access the data your Ruuvi Gateway is sending to the cloud. To keep your sensors safe, make sure you always claim all your sensors. Sensors that don’t have owners can be claimed by someone else.
Web interface
Once your ownership has been set up, you can access data of the sensors stored in the cloud. In addition to the mobile app, you can access your sensors via web interface on ruuvi.com/station
Use the same email address in mobile app and web app. You will receive a one time login code to your inbox. Your login session will stay valid until you log out or clear the cache on your web browser.
Sharing your sensors
Now you can share your sensors with your friends and family. Go to the sensor settings view on the mobile app to share the sensor. Your friend will get an email notification and will be able to see your sensor on his/her Ruuvi Station.
Are you an advanced user?
Ruuvi Gateway can also be configured to your liking.
Read more about advanced configuration:
ruuvi.com/gateway-config
Join the Gateway discussion
You can reach out to our team and fellow Gateway users on the Ruuvi Forum at: f.ruuvi.com
