RuuviTag not visible in Victron Cerbo GX
Victron has integrated RuuviTag sensor compatibility into Venus OS 2.80, allowing your RuuviTag sensors to be added to supported systems like the Cerbo GX monitoring system, and it’s predecessors the Color Control GX, Venus GX and more.
However, the Cerbo GX’s built-in Bluetooth radio is not reliable enough to work with Ruuvi sensors. As a result, Victron advises installing a Bluetooth 4.0 USB adapter when using Cerbo GX with RuuviTag sensors.
A list of tested adapters is available here. The main concern is related to internal temperature, which means the system may function without problems in colder conditions. Nonetheless, for best performance and reliability, using a recommended Bluetooth adapter is advised.
More information about RuuviTag and Victron integration can be found here!
