Ruuvi Station is an easy-to-use application that allows you to monitor the measurement data of Ruuvi’s sensors.
Ruuvi Station collects and visualises Ruuvi sensor data, such as temperature, relative air humidity, air pressure and movement from local Bluetooth Ruuvi sensors and Ruuvi Cloud. Additionally, Ruuvi Station allows you to manage your Ruuvi devices, set alerts, change background photos, and visualise the gathered sensor information through graphs.
Our mobile App is specifically designed to work with our Ruuvi Sensors. Ruuvi Station is available for both Android 5.0 and iOS 14 or newer compatible devices.
Ruuvi Station Android
Ruuvi Station iOS
Beta versions of Ruuvi Station mobile app are also available:
Ruuvi Station Beta Android
Ruuvi Station Beta iOS
Updating Ruuvi Station
We are constantly improving our Ruuvi Station app. Please make sure you are running the latest version of Ruuvi Station to keep up with the latest features and bug fixes.
Ruuvi Station will be automatically updated, as long as you have allowed automatic updates on your mobile device.
Minimum Requirements
Ruuvi Sensors are Bluetooth Low Energy compatible sensors and they work with all Bluetooth Low Energy enabled devices. Ruuvi Station App mobile has been tested to work with Android OS 5.0 (Lollipop), iOS 14 and higher versions.
Getting Started With Ruuvi Station
Detailed instructions to get started with the app and the monitoring experience can be found here.
