Data centers are the heart of digital operations, hosting critical IT infrastructure that generates substantial heat during operation. Monitoring temperature in these environments is essential for preventing equipment failures, optimizing energy efficiency, and ensuring compliance with industry regulations.
Excessive heat can lead to hardware malfunctions, downtime, and costly repairs. Maintaining an optimal temperature range—typically between 22°C (72°F) and 25°C (77°F)—is crucial to avoid these risks. Additionally, humidity levels must be controlled within 30% to 60% to prevent static electricity or condensation, both of which can damage sensitive equipment.
Simplify Monitoring with RuuviTag
RuuviTag sensors offer a reliable and easy-to-use solution for monitoring environmental conditions in server rooms. By placing sensors near server racks, air intake vents, and exhaust points, data center managers can collect accurate temperature data to identify hotspots or airflow issues. With Ruuvi Gateway, real-time remote monitoring becomes seamless, allowing centralized access to environmental data across large facilities.
Ruuvi’s cloud interface makes reporting simple and efficient, helping data centers meet regulatory requirements without hassle. For colocation providers where monitoring conditions on an industrial scale is vital, Ruuvi sensors integrate effortlessly into existing systems to streamline operations.
Benefits of Using RuuviTag
RuuviTag sensors help prevent overheating by providing early alerts for temperature spikes. They simplify compliance with reporting standards and consolidate all monitoring tasks into one system, eliminating the need for multiple tools. With their compact design and wireless connectivity, RuuviTags are ideal for creating a reliable and efficient environment for critical IT infrastructure.
Whether you’re managing a single server room or a global network of data centers, RuuviTag ensures your equipment stays safe while reducing energy consumption and operational costs.
Buy Your Own RuuviTag
Store your products in the correct conditions
Excellent!
Battery Box
Engel Fridge
Main Rapido Fridge Area
I have now configured:
High temperature alarms
Low temperature alarms
VRM email notifications
the battery box overheats
